Rear End Code Decipher Help - NCRS Discussion Boards
  • Larry E.
    • 1693
    Can someone try to decipher the code on the picture given. Code does not
    match up with the new 66 TIM & JG manual. Thanks in advance.
    Larry
    Larry
    LT1 in a 1LE -- One of 134
    Re: Rear End Code Decipher Help
    Larry
    Larry -
    "FC" was a 4.56 Posi Big-Block axle from '65-'69, but I don't think Julian dates were used until 1971; what's the diff housing casting date (driver's side, partially obscured by the strut rod bracket)?
    • Kenneth T.
      • March 23, 2008
      • 631
      I have posted a picture of the codes for several years. The last line for '66 shows an FC code.
      Hope it helps.
      Ken
      • Larry E.
        • 1693
        Larry -
        John:
        Can not get to car right now to look at casting date as it is sealed in a "OMNI"
        bag right now. Don't know when I will "unbag it".
        Larry
        Larry
        • Larry E.
          • 1693
          OK we know the FC is 4:56 ratio HD Posi and "W" is for the Warren MI Plant. Has anybody ever seen a 65-69 coded Rear Axle with a Julian
          Date instead of the normal M-DD-YY Date? Any pictures out there?
          Thanks in advance. Larry
          Larry
            • 15625
            Larry, as you know we don't routinely judge differential codes, but I have never heard of a 1968 to 1970 with an originally installed Julian dated differential. I would have to do some research to find out if the Julian date system began in late 1970 production or if the standard system carried over into early 1971, but that is a long way from your Corvette.
            • Larry E.
              • 1693
              Moved this up once more for final time. Can anybody post a picture of a Julian dated 1971 or up for comparison? Thanks; Larry
              Larry
              • Larry M.
                • January 1, 1992
                • 2701
                Larry:
                No pictures..........sorry. I suspect this to be a later GM over-the-counter replacement. Previous owner may of had extra $$ to buy new GM parts or worked for a GM dealership. That's why codes and other markings are factory correct, but with a later date.
                Larry
