My 66 temp gauge just went to "zero" ( actually all the way left around 100*). It was working this morning on my way to a show but when I stopped for gas on the way home I noticed the gauge is at 100. I tried wiggling the connector at the sender but gauge is still dead or 100*.
A quick search of the archives gives me 2 tests.
Check the sender by boing it in water and measuring the resistance. expected value around 100 ohm.
Check wiring and gauge by inserting a 40 ohm resistor between sender lead and ground and gauge should be at the high end.
A lot in the archives about not accurate readings but I could not find the "dead gauge" condition. The fuel gauge works so I don't think it is a blown fuse.
All the gauges were redone around 5 years ago so hopefully it isn't the gauge itself.
Randy
Randy
