Battery shutoff swithches - NCRS Discussion Boards
  • David A.
    • July 31, 1999
    • 147
    Re: Battery shutoff swithches
    believe it or not
    he's been mayor for the past 25 years
    no one has every run against him!!
    he is a friend of mine
    and wishes to be impartial.
    but, i haven't won 'peoples choice' either!
    think last year
    an old 'duster' won it!!
    iowa
    • Joe R.
      • May 31, 2006
      • 1822
      Originally posted by David Ahrens (32690)
      i'm not trying to be a smart A**
      but am just curious as to why
      one needs a shutoff switch?
      is this just to avoid the inconvinence
      of disconnecting the battery when working on your cars?
      the original cars did not have them,
      and this is 'thee site' for corvette restoration.
      a short free electrical system,
      coupled with a well maintained battery
      and a car that is driven once in a while,
      should not need such a device.
      i confess, i do have them on my 6volt WW II jeeps,
      but not on my 56 vette!!
      iowa
      Iowa,
      There is one more reason I didn't see mentioned - bonus judging points. Bonus points are awarded for a battery switch, fire extinguisher and NCRS sticker.
      Joe
      • David A.
        • July 31, 1999
        • 147
        #18
        interesting
        many things could be done to these old cars
        to make them safer;
        disk brakes, air bags
        (protection against the real killer; accidents)
        etc.
        i'll just have to accept
        these are non-original allowances
        in the name of neccessity
        iowa
        • Robert S.
          • May 31, 1988
          • 81
          #19
          On my 60, I just keep the negative cable loose and twist it on and off. The cable, in the off position, rests on the battery hold down bolt. Never had a problem and it is free.
          • David A.
            • July 31, 1999
            • 147
            #20
            i have given this a little more thot and.......
            it seems a paradox to me
            when non originality is excepted as the norm,
            and even awarded bonus points!
            on a site that is the gold standard on corvette restoration!
            it seems to me that the acid tested standards
            would dictate that one simply disconnect the negative ground
            each time instead of installing a battery shut off switch!!
            with a wrench at the ready
            this would take all of a few seconds!
            iowa
            • Valeria H.
              • July 27, 2009
              • 463
              #21
              It costs all but $4.00 to buy a disconnect cable leveled on the negative pole. Why take the chance. It is your choice and it is your car.
              Valeria Hutchinson
              Past Chairman of the Carolinas Chapter
              1960 Roman Red w/ White Coves -"Bella"
              2005 Millennium Yellow 6 speed 400 HP - "Trixie"
              • David A.
                • July 31, 1999
                • 147
                #22
                really, i'm not trying to be obtuse.
                if i thot that i was taking a chance,
                i'd simply disconnect the original
                lead to the battery post!
                i really don't think it would take much
                longer to do this then use the shutoff switch.
                even if i used this shut off switch,
                i'd think it would be logical to remove it for judging!
                but, enough said,
                and will ask this question,
                is this the correct neg lead to a '56 battery?
                iowa
                • Ronald L.
                  • October 18, 2009
                  • 3248
                  #23
                  Richard M mentioned something that got glossed over...
                  On a C2 the system is still hot in various locations if you have a neg cut off switch.
                  He mentioned part of the ignition system, also the starter is still hot, might be other.
                  • David A.
                    • July 31, 1999
                    • 147
                    #24
                    are you saying that
                    with the battery disconnected
                    that there are still lines
                    that are hot?
                    iowa
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11367
                      #25
                      A bit of confusion I think......Yes those items are hot and unprotected, but if the battery ground is disconnected, at the battery, nothing is hot.
                      What I was trying to explain was if both battery cables are connected, i.e. normal connections from the factory.......
                      The positive battery cable connects to the starter solenoid. To power the rest of the car, there is then a #10 wire also connected at the same point on the solenoid. This cable runs up through the engine harness directly up under the dash and into the ammeter. One thing to keep in mind is that over the years the harness can move around and can be cut by the steel wiper cables. This would cause a direct short from the ground of the wiper system.
                      The other terminal on the ammeter then feeds the fusebox to protect all circuits, that are fused. The #10 wire going to the ammeter is unprotected. The wire on the other terminal of the ammeter feeding the fusebox is unprotected.
                      Also, from the output terminal of the ammeter, there is another red wire feeding the clock and the lighter. Both of these circuits are unprotected. They do not come from the fusebox. That is why it is a good idea to put inline fuses for both.
                      Rich
                      • Jim L.
                        • September 30, 1979
                        • 1817
                        #26
                        Impossible.
                        If the battery is disconnected, the electrical system is dead. Makes no difference whether it's the connection at the positive post or the negative post. Either way, the system is dead.
                        Jim
                          • 15641
                          #27
                          but, enough said,
                          iowa
                          How many times do you think you can disconnect/connect that terminal before it wears out? It was not designed to be connected/disconnected multiple times, and will fail sooner rather than later if used regularly for that purpose.
                          The ultimate restoration is to keep your Corvette from being damaged. Disconnecting the chemical energy source goes a long way to protecting your Corvette from unintended damage. In the end it is your car, and if you wish to set it on fire in one of the large fields you have in Iowa that is your choice.
                          • David A.
                            • July 31, 1999
                            • 147
                            #28
                            i guess inline fuses,
                            which are out of sight
                            would be the lessor of
                            non original evils.
                            i like my 56
                            and don't want it to burn up!!
                            the shut off switch would be very convienant.
                            but if i went to all the trouble of
                            disconnecting the negative lead manually
                            and lost to
                            a car equal to mine being judged
                            simply because it didn't have a SOS,
                            i'd be a little disillusioned!
                            sorry to harp on this topic
                            as you can see from pics of my car and engine bay
                            i'm an original purist in theory
                            but not in practice!!
                            iowa
                              • 15641
                              #29
                              non original evils.
                              i like my 56
                              and lost to
                              iowa
                              You will not lose to another car in any NCRS meet because we don't judge one car against another. ALL cars are judged against a theoretical standard, and every car can "win" or no car can "win." What is more you will get 3 additional points (out of slightly more than 4500) for the battery cut off switch from NCRS. So in NCRS judging you will have an advantage -- but that will not matter.
                              • David A.
                                • July 31, 1999
                                • 147
                                #30
                                no, i don't want to see that happen!!
                                i see your points.
                                this recent/old NCRS upstart
                                will heed your advice!
                                now, is my negative lead correct?
                                iowa
