64 vent window regulator rebuild - NCRS Discussion Boards
+ More Options
Posts
  • Michael Y.
    • July 23, 2010
    • 28
    I am in process of rebuilding my roadster vent window regulators. The question I have is which rebuild kit to buy. The choice is the kit from paragon, which has original material gears, or the kit with the aircraft aluminum gears, which are supposed to last longer. Does anybody have any experience with these kits, or any input? Thanks
  • Jim D.
    • 2885
    Re: 64 vent window regulator rebuild
    https://www.forums.ncrs.org/showthre...=vent&uid=9160
    • Gene M.
      • April 1, 1985
      • 4233
      Mike,
      It does not matter which gears you use. If you want no slop in the operation (as in better than ever made to meet the NCRS judging PV and operations requirements) you need to tighten up on the gear center to center spacing. Closer spacing cuts down on back lash that reduces slop in the handle operation. Problem is with a lot of use the slop returns.
      Much of this has been discussed previous.
