Big Block Idler- Why Fixed? - NCRS Discussion Boards
  • Rich C.
    • January 1, 1994
    • 383
    I've never quite understood how the idler pulley, being fixed, accomplishes anything. If it was spring loaded, that would be one thing, but....?
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: Big Block Idler- Why Fixed?
    Rich,
    Not to speculate, please post a picture.
    • Tom L.
      • October 17, 2006
      • 1439
      Dave, I'm pretty sure the water pump belt that uses the idler on a/c cars and the water pump on non a/c cars is the same part# 3952336. I think the idler pulley is there on a/c cars to maintain tension as it wears/streaches over time. Either way, the belt will NOT fit onto the pulleys without removing one, it's a chore at best.
      • Dick W.
        • 10483
        Unless we are talking about different parts, all the BB idler pulley's I have seen, sold, installed, judged, etc have been adjustable??
        Dick Whittington
        • Tom L.
          • October 17, 2006
          • 1439
          Sorry if I wasn't clear, the pulley is adjustable. I meant that it would be adjusted according to wear periodically, which would prevent slippage.
            Lynn -
            There were no spring-loaded idler pulleys until the serpentine belt drive systems appeared during the C4 era.
            • Rich C.
              • January 1, 1994
              • 383
              Yes they are 'adjustable', but locked in place with nut/lockwasher. So they don't act like a sepentine idler. They were installed on BB's with A/C.
              • Rich C.
                • January 1, 1994
                • 383
                No ideas? Anyone?
                  Originally posted by Rich Cousineau (23820)
                  No ideas? Anyone?
                  Rich -
                  The idler bracket is adjustable to maintain tension on the drive belt, just like the adjustments on the brackets for the compressor, alternator, and power steering pump belts.
