Electric Choke Power - NCRS Discussion Boards
  • Dave G.
    • February 21, 2007
    • 14
    The carb I have has an electric choke where is a good place to pick up the 12v power source? My car is a 1964 roadster,thanks.
    • 6950
    Re: Electric Choke Power
    Dave, how about the positive side of ing. coil, that is switched ing.
      You don't want to use the coil (+) terminal - that has ballast resistor-reduced current, and the electric choke requires a full 12 volts or the choke won't open all the way. You can use the bottom terminal on the ballast resistor where the 18-ga. black/pink wire is connected that comes through the firewall grommet, or feed it from the fuse block "Ign" cavity; both of those provide switched 12V ignition power. An in-line fuse in that wire is a good idea, to protect the ignition circuit.
        • 6950
        John, Whoops, I forgot the resistor.
