hey guys...i have a 66 base motor (300hp) with a holley and cast iron intake. all correct of course. when i pulled the carb off i kept all the gaskets in the order that they were installed. they went as follows...intake, thin gasket, baffle plate (thin metal), the insulater spacer (thicker gasket) and finally the carb. according to all my books i am finding that not only is this sequence wrong, but it is only listed for the 63-65 AFB carb. i struck out looking in my assembly manual. all the parts catalogs have it listed this way...intake, thin gasket, insulater spacer (thicker gasket), baffle plate (thin metal) and then the carb. but, again it's only for the 63-65 AFB carb. the catalogs list only the thin base gasket for the 66 base motor with a holley. do i need ALL the gaskets listed in the catalogs for the 63-65 afb carb like mine had when i pulled it apart or just the 1 base gasket? which ones does my 66 actually need? please help and thanks in advance.
