Rebuild on the L89 is now about 5 years old. Car doesn't seem to have any issues except it does run a bit rough until it has warmed up fully. I am trying to decide on whether or not I should rebuild the tri-power. Is there set of tests I can do myself to try and figure this out? There are no leaks or issues that are readily apparent.
I would also like to get some thoughts on best weight / color for scondary springs. Is there a good way to get more of progressive feeling out of the tri-power?
Thanks in advance for the help
Noel
Noel
