Correct spark plugs for 63 - NCRS Discussion Boards
  • John S.
    • May 17, 2009
    • 164
    What is the correct spark plug for a 63, 250HP engine?
    I ordered a set from Corvette Central and got AC 45S, are those correct? I thought AC 44 were the right ones.
    Any help on this?
    John
  • Joe R.
    • July 31, 1976
    • 4552
    Re: Correct spark plugs for 63
    The 45's are a little hot unless you have an oil burner. 44's would be my choice for normal street driving and 43's for autocross etc.
    JR
    • Larry M.
      • January 1, 1992
      • 2703
      Although I generally find myself agreeing with JR, I think you will be fine with R45S.
      Even back in the day, 44 plugs were a bit too cool for the street and would foul. Especially apparent if you were in a race and didn't check/change your plugs first. Many folks (self included) switched to 45.
      All AC plugs since the late 1960's are the R or resistor type. This is okay. The S indicates extended tip. Also okay, especially for the non-SHP engines.
      I have about a dozen boxes of vintage AC 44 plugs for my 1967 327/350 HP car on-hand, but run AC 45's in it currently. PS: It burns no oil
      Larry
      • John S.
        • May 17, 2009
        • 164
        I am mainly looking for what will pass NCRS judging, got dinged on plugs, so not sure what is needed there.
        John
        • Larry M.
          • January 1, 1992
          • 2703
          John
          John:
          I didn't think we had digressed to that level of detail yet. I'm generally okay if I just see an AC plug with green lettering/rings, regardless of the heat range.
          But for judging, you need AC 44 plugs with 4 equal/thin green rings at the top. They are about $40-50 a box and can be purchased from various ads in the Driveline or on Ebay. Not three rings......not four rings with one thick one, not all white, but four equal/thin green rings
          Larry
          • John S.
            • May 17, 2009
            • 164
            Originally posted by Larry Mulder (20401)
            John:
            Larry
            Larry,
            So just AC 44 and four equal thin stripes with no other number/letter? Not extended reach plugs. A pain for just one deduct point, but guess I have to be correct.
            John
