69 fan clutch - NCRS Discussion Boards
69 fan clutch
  • Jim M.
    • February 23, 2009
    • 233
    69 fan clutch
    While sprucing up the engine bay on my 69 350/350 I noticed that a previous owner had repainted the fan and but got black paint all over the fan clutch. Is there anything I could damage by spraying on some paint stripper to clean it off?
    Re: 69 fan clutch
    Jim -
    Shield the area of the rear seal where the shaft enters the clutch; you don't want stripper to get on/in that seal. Don't let it get to the front either, where the valve actuating pin in the center enters the front cover.
    • Dennis C.
      • June 30, 2002
      • 888
      Re: 69 fan clutch
      Jim,
      Try using carb cleaner. You can even spray it on a rag.
      Dennis
      • Jim M.
        • February 23, 2009
        • 233
        Re: 69 fan clutch
        Thanks John, Dennis, sounds like I need to be careful cleaning off the overspray. jim
