LED Tail Lites on Midyear - NCRS Discussion Boards
  • Gene M.
    • April 1, 1985
    • 4233
    Has anybody used LED lite bulb replacements on Midyear tail lights?
    How many LEDs?
    Any special manufacturer?
    Are they a lot brighter?
    Do the turn signals blink OK?
    Do the bulbs fit in the housings?
    As you suspect this is for a driver not flight judging.
    • April 1, 2000
    • 477
    Re: LED Tail Lites on Midyear
    FYI, I had bookmarked a previous discussion on this topic.
    Check out https://www.forums.ncrs.org/showthre...=1157&uid=9243 for some previous discussions on this topic.
    • Gene M.
      • April 1, 1985
      • 4233
      thank you Jack.
      I think I'll stay with the old fashion bulbs since they look brighter in the photo.......
      • Dick W.
        • 10483
        Gene, I have LED bulbs in everything we own. I have learned bulbs are not equal. With that said, the time it takes for a LED to illuminate is one car lenght shorter at 60 mph. How many rear end collisions would that prevent?
        Dick Whittington
        • Gene M.
          • April 1, 1985
          • 4233
          Dick, the earlier someone else can see my tail lights the better. What brand, model number are you using on your mid yr vettes that is brighter than the old bulbs.
          The photo in the old posting didn't look as if the LED's were brighter......yes/no?
          Also do the brighter LED bulbs fit in the mid yr tail light housings without modifications. Some of them look kinda big...yes/no?
          • Bruce B.
            • May 31, 1996
            • 2930
            Gene,
            Check out www.uapac.com, they manufacture L.E.D. tail light assemblies for Corvettes through 1996.
            They also sell L.E.D. bulbs which I personally do not recommend.
            Check your email.
            Bruce B
              • April 1, 2000
              • 477
              Gene,
              Check your email.
              Bruce B
              Bruce,
              Can you send me the same email/pm?
              I think I know what it is referring to, and I may be interested myself.
              • Dick W.
                • 10483
                Fleabay bulbs, just read the specs, find the brightest. They went into the housings on a '72 which are about the same as far and opening for the bulb and the depth.
                Dick Whittington
                • Bruce B.
                  • May 31, 1996
                  • 2930
                  Jack,
                  I sent you an email.
                  Bruce B
                  513 267-3706
                  • Jack C.
                    • August 31, 1993
                    • 29
                    Gene: I have the uapac lights in my 67, I think they are safer and agree with Dick.
                    The only problem I had was getting the wire pigtail to wind up tight enough to fit inside the lens cone. The wire kept trying to get under the edge of the lens and get pinched. It just took some work to not pinch the wires. I've had them in for over a year. Ordered from an ad in Driveline, guy in Dayton OH area.
                    Good Luck
                    Jack Coffman
                    • Bruce B.
                      • May 31, 1996
                      • 2930
                      Jack,
                      I agree with your comment concerning the wires on the UAPAC tail lights and I have suggested to the manufacturer that they shorten the wires and reduce the wire size.
                      Since the lights draw very little current a larger gauge size wire would be sufficient and also result in a cost savings.
                      Bruce B
                      • Dick W.
                        • 10483
                        Bruce, you have to be careful when you reduce the wire size. It reduces the strength of the wire and could result in breaking due to vibrations. The have to have extra support
                        Dick Whittington
                        • Bruce B.
                          • May 31, 1996
                          • 2930
                          Dick,
                          Good point.
                          I'll leave it up to the engineers.
                          Bruce B
                          • Gene M.
                            • April 1, 1985
                            • 4233
                            Guys, thank you for the response.
