74' Intermitant Brake Light - NCRS Discussion Boards
  • Robert S.
    • June 30, 2001
    • 230
    The brake light comes on randomly and I can get it to go off by tapping the brake petal a few times. No signs of leakage, braking is normal and master cylinder fluid level appears about normal on both sides - however a little lower in the rear side than the front. I do not know the entire history of the brake system but I believe the wheels all have stainless steel sleeves and I know the brake hoses are new. I think the master cylinder is original and untouched.
    I am thinking my problem is the master cylinder and to pull it and have it sleeved and rebuilt. Any thoughts from others who may have had this type of problem?
  • William C.
    • May 31, 1975
    • 6037
    Re: 74' Intermitant Brake Light
    Based on your description, I'd have the Master Cyl rebuilt IMMEDIATELY before driving the car anywhere.
    Bill Clupper #618
    • Michael D.
      • June 30, 1996
      • 536
      The BRAKE light indicates a problem with the system. Based on your post, the cause could be the master cylinder. Regardless, check the entire system and ensure you have no obvious leaks.
      • Russ S.
        • April 30, 1982
        • 2162
        Is your pedal soft at all? I would bleed the brakes first thing.
        • Jim T.
          • March 1, 1993
          • 5351
          Bleed both rear calipers and see if you have results.
