151 Mile 1970 LT-1 Coupe??? - NCRS Discussion Boards
  • Paul B.
    • April 30, 1995
    • 482
    Page Not Found. Here are some quick links to the top Mecum Auctions pages to get you back on track quickly.
    ....Hmmmmmmmm,......
    ...probably the "most original" in the world???
    ...a pic is worth a thousand words.
    GO......
    • January 31, 1988
    • 43197
    Re: 151 Mile 1970 LT-1 Coupe???
    Originally posted by Paul Borowski (26140)
    http://www.mecum.com/auctions/lot_de...=SC0511_T240.1
    GO......
    Paul-------
    151 miles but it's had both its waterpump and master cylinder replaced and both replaced with incorrect pieces at that.
      • November 30, 1989
      • 11613
      151 miles since restoration is probably correct.
      Exhaust replaced, front spoiler and attaching hardware replaced, paint on plunger(s) in door jamb(s), missing emissions sticker, repro air cleaner hose, oil filler on wrong side, blah blah blah.
      My 61000 mile 72 is much more original than that car.
      Patrick
      • Jim T.
        • February 28, 1993
        • 5351
        No expert here, but the air injection system is missing and the radiator is to large. No aluminum expansion tank.
          • January 31, 1988
          • 43197
          Jim------
          Yes, the missing AIR system is another obvious element of incorrectness. I should have picked that up at a glance; I guess I looked at the photos too quickly.
          The radiator and lack of supply tank is probably correct, though. Most 1970 LT-1 did use the copper/brass radiator without supply tank.
          Overall, this car is not even an accurate restoration, which casts further grave doubts on it being 151 original mile car.
          And this car scored a Top Flight?????
          • Dave S.
            • August 31, 1992
            • 2922
            Jim------
            The paint job on the motor looks like it has 151 miles also. They just all happened in the last month. I can't wait to see how this one sells. I hope somebody pays $500,000 for it.
            • Ronald L.
              • October 18, 2009
              • 3248
              And the air filter...
              • Reba W.
                • 934
                Glossy door jams....
                • Paul O.
                  • August 31, 1990
                  • 1716
                  Ride height rear to high, engine compartment black out over done, front license holder has 4 white nuts should only be 2 and do not see the TCS solenoid on right side of intake manifold. The radiator should be brass/copper hence no expansion tank ZR-1 would be Aluminum. Way to many small and large items to be an unrestored 151 mile car. But it is just our opinions and will they hold water when tested.
                  Paul 18046
                  • Michael W.
                    • March 31, 1997
                    • 4290
                    In 2002. Lots of time since then to 'fix' all sorts of things.
                    • Michael J.
                      • January 26, 2009
                      • 7091
                      You know I see cars like this all the time. You do wonder why anyone puts out misleading, cherry-picked info. Why not just tell the whole story? Are there that many ignorant people out there that would spend big bucks without looking closely? I would hope not, but......
                      • William C.
                        • May 31, 1975
                        • 6037
                        Might lead you to some conclusions about what an "honest broker" a particular auction service may (or may not) be.
                        Bill Clupper #618
                        • Jim T.
                          • February 28, 1993
                          • 5351
                          Jim------
                          Joe I was lazy, I should of looked at my second edition Vette Vues Fact Book by M. F. Dobbins concerning my post. The Fact Book shows the LT-1 with the larger radiator and composite fan shroud. The pictures clearly show no supply tank and the radiator with a pressure cap.
                          The pictures of the 1970 ZR-1in my Fact Book has the steel fan shroud and smaller aluminum radiator. On page 116 it shows the individual picture of these items. It also says " Harrison aluminum radiator, 3007436, and metal fan shroud used with the racing package LT-1, the ZR-1."
                            • January 31, 1988
                            • 43197
                            Jim------
                            I think it's possible that some 1970 LT-1, particularly early cars, were built with the 3155316 aluminum radiator. If so, it was the exception rather than the rule.
                            • Jim T.
                              • February 28, 1993
                              • 5351
                              Jim------
                              Terry M. has a early 1970 LT-1, he can verify if his LT-1 came with the aluminum radiator.
