63 Steel Wheel repair - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5332
    The lug nut holes in my 63 wheels have become elongated or too large as a result of over tightening them. I'm sure they can be repaired but I just can't find anyone in the Northeast that provides this service.
    Has anyone else had this repair done on their wheels, if yes, where?
  • David L.
    • July 31, 1980
    • 3310
    Re: 63 Steel Wheel repair
    Harry,
    Back in 1998 I bought 4 almost new "take off" original GM S10 alloy wheels w/tires for my 1998 S10 from a place called New England Wheel in Hampton Falls. They also sold reconditioned wheels as well as repaired wheels but I know absolutely nothing about the quality of their work.
    Dave
    • Harry S.
      • July 31, 2002
      • 5332
      David, they went out of business a few years back. Lost the business to a fire.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11345
        Harry,
        Tip tip of the nut contacts the drum before the lug hole? Until you find a wheel repair shop, maybe this as a temporary solution......Shaped washers behind the lug nuts.
        Using a press and sacrificial lug nuts, bend thick SAE washers to form the correct ID bevel. You'd need a round backup object for the press to get the correct conical shape OD for the wheel lug hole. 5 for each wheel to keep them balanced.
        I've also seen where people grind the backside of the nut to reduce the depth of the nut, but I'm not sure I like that idea.
        Rich
