Front Nose Emblem - No Dum Dum?? - NCRS Discussion Boards
  • Kirk M.
    • June 30, 2006
    • 1036
    That is what is written on my judging sheet. What exactly does that mean? Thanks.
    Kirk
  • Grant W.
    • December 1, 1987
    • 407
    Re: Front Nose Emblem - No Dum Dum??
    Kirk
    Hi Kirk
    The stamped nuts that hold onto the 2 pins. The original factory nuts should be filled with a dark puddy or dum dum. When the nut is screwed onto the pins the nut tightens to the fiberglass and the excess puddy will oz around the nut.
    You will see this type of dum dum around your heater box fiberglass mounted on the firewall.
    Hope this helps.
    Grant
    • Gene M.
      • April 1, 1985
      • 4233
      Kirk,
      My opinion, a judge that can see inside the two holes where the nose emblem is fastened and discern the presence of dum dum under the nuts is just not reasonable.
      • Kirk M.
        • June 30, 2006
        • 1036
        Can you buy dum dum somewhere? I have some of that tar-like stuff that you find around the AC pipes and some of the holes in the firewall, but I'm assuming dum dum is something a little different.
        Kirk
        • Stuart F.
          • August 31, 1996
          • 4676
          I bought a package many years ago (or something just like it) from an auto parts store. It came as a rope material all wound up in package about 8" long x 2" wide. Still have it, or whats left of it. Believe it was 3M.
          Use of the material helps seal against moisture I guess, but like what has been said, it oooses out around the nut and that makes it visable.
          Stu Fox
            • 6956
            Kirk, 3M ( 08578 part no.)makes strip calk that you can use, if you know someone at a body shop, maybe he has a few pieces. instead of buying a box.
            • Paul J.
              • September 9, 2008
              • 2091
              Stu and Ed have it, 3M strip caulk. Here's a thread with pictures.
              https://www.forums.ncrs.org/showthre...m-dum&uid=2197
              • Jim D.
                • 2885
                Originally posted by Gene Manno (8571)
                Kirk,
                I agree. That's taking judging to a ridiculous level.
                • Carl N.
                  • April 30, 1984
                  • 592
                  You can buy a box of 3M thru Eastwood. Last box I bought was about 5 years ago and less than $20.
                  Will last you a lifetime just keep the box in a freezer bag after you open.
                  I also use it around wall sockets and switch plates in the shop to stop drafts and water lines to the shop sink to keep out mice.
                  Carl
                  • George C.
                    • November 1, 2001
                    • 568
                    Kirk,
                    I have a box that I will never use up. If you send me your address I will send you a couple lengths of the rope caulk.
                    George
                    • Paul B.
                      • April 30, 1995
                      • 482
                      ...I like using chewing gum-plus the stickiness of the gum at first attracts dust giving it that "aged, original" look.
                      ...just don't used "flavored" gums that are green, pink, etc. An absolute deduct!!!
