Master Cylinder date/timing - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1299
    Re: Master Cylinder date/timing
    Ed,
    What does the R2 stand for?
    • Gerald C.
      • June 30, 1987
      • 1299
      Ed,
      If I eliminate the "I", wouldn't the date be September?
        • 6948
        #18
        Jerry ,You got me thinking. I may be wrong about the (I), I will do some research and let you know.
          • 6948
          #19
          Okay, Jerry I received some data and the is no {I)SO Your master is Sept. which works better for your car. Now I have a question for you, Does the font on the cap have 1/8"letters or are they 1/4" thanks Ed. Oh the R-2 must be some sort of casting /mold no. I have a J10 casting in my collection and it has the bigger letters.
          • Gerald C.
            • June 30, 1987
            • 1299
            #20
            Ed,
            The letters on the cap are 1/4". Is there a relevance to the size? Also, I'd like to freshen up the m/c. Can I use that Stove Black polish that has a dull finish on the m/c?
              • 6948
              #21
              Jerry, when you look at the judge guide it only spells out 1/8 inch letters, I Believe that he early master cylinders had the bigger letters. I think a semi flat or Satin Black will work just fine.
              • Harry S.
                • July 31, 2002
                • 5330
                #22
                The stove black will take the engine compartment heat better.
                • Gerald C.
                  • June 30, 1987
                  • 1299
                  #23
                  Ed,
                  That 1/4" size would coincide with my 10/31/62 build date. So far all the research I'm doing and finding is leading to a very original car. Kind of nice.
                  Jerry
                  • Gerald C.
                    • June 30, 1987
                    • 1299
                    #24
                    Thanks Harry
