Carburator Installation Tonawanda/St. Louis - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    Were the carb setups installed at St. Louis? If so, how were the engine run tests conducted (natural gas) before shipment at Tonawanda? Especially the tri-power cars. I saw a similar question on the other forum.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
  • Larry M.
    • January 1, 1992
    • 2701
    Re: Carburator Installation Tonawanda/St. Louis
    Yes they were. Natural gas used to test fire engines at the engine plants.
    Larry
    • Tom H.
      • December 1, 1993
      • 3440
      John Hinckley has posted a great photo of the dry fire rig they used at the plant. I can't find it. I know it's here somewhere !! Maybe John will chime in and post it.
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • Jack C.
        • 1090
        Would love to see it.
        Jack Corso
        • Chuck S.
          • April 1, 1992
          • 4668
          The purpose of a carburetor is to meter and atomize LIQUID gasoline into a fine mist, mix it with air into the proper fuel/air ratio, then meter the mixture into the intake manifold as required.
          Since natural gas is already in a gaseous state, much of the complication of the carburetor is un-necessary; the configuration of the fuel system needed for hot run at the factory likely had little resemblance to a carburetor.
          • Bill M.
            • April 1, 1977
            • 1386
            Found it: Thanks, John.
            • Tom H.
              • December 1, 1993
              • 3440
              That's it !!!
              Tom Hendricks
              • Bill M.
                • April 1, 1977
                • 1386
                Here's a page from the Restorer, Vol.18, no. 3. Article written by Terry McManmon about the Tonawanda Mark IV assembly line. This page covers hot test.
                I was there when they were doing tri-powers. but don't remember any details of the adapter for that manifold.
                • William H.
                  • January 11, 2010
                  • 65
                  Wow thanks Bill
                  • William H.
                    • January 11, 2010
                    • 65
                    New question, Was the tri power manifold add at st. louis also?
                    • Lawrence M.
                      • February 1, 1995
                      • 404
                      The 1969 AIM in UPC L71 sheet A1 shows installation of the 3x2 carb and choke. So I would say they were installed at St. Louis.
                      Larry
                      2002 Z51 Convertible
                      1969 L46 Convertible
                        • 15621
                        ALL manifolds (inlet and exhaust) were installed on the engine assembly at the engine plant.
