65 396 Oil Pan Pictures? - NCRS Discussion Boards
  • Mark P.
    • July 31, 2003
    • 407
    Could I get someone to send me (or tell me where I can find) some pictures of an original early May 396 oil pan? I'm seeing different configurations, some of which must be replacement pans.
    I appreciate the help!
    Mark
    Mark Pugmire
    54 Pennant Blue
    56 Cascade Green Dual Quad
    56 Arctic Blue Dual Quad
    66 Nassau Blue 427 L36 Convertible
    67 Marlboro Maroon L79 Coupe
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 65 396 Oil Pan Pictures?
    Originally posted by Mark Pugmire (40391)
    Could I get someone to send me (or tell me where I can find) some pictures of an original early May 396 oil pan? I'm seeing different configurations, some of which must be replacement pans. .....
    [TTT]
    Mark, can you give us a little more detail ? Are you saying that there may be differences between an early May pan and later in the model year ?
    The '65 TIM&JG describes oil drain plug location, sump length, vertical ribs (number & location), corner reinforcements, etc.
    • Mark P.
      • July 31, 2003
      • 407
      Originally posted by Wayne Midkiff (3437)
      [TTT]
      Wayne,
      I'm just saying that there are different configurations on 396 oil pans between replacements adn originals. The car I'm looking for a pan for is an early May car and I just want to see an early original pan or pictures so I can make sure I get the right one. A visual makes a big difference. hard to believe that nobody has a picture of a pan they can share.
      Mark
      Mark Pugmire
      54 Pennant Blue
      • Gary C.
        • April 1, 1998
        • 380
        Mark,
        I can send a photo of mine but I have been told its not correct because it does not have the bolt that fastens to the timing cover at the front!
        So I would also like to see a correct one as well?
        Cheers,
        Gary
        • Wayne M.
          • March 1, 1980
          • 6414
          Originally posted by Gary Cowans (30373)
          Mark,
          So I would also like to see a correct one as well? ...
          Or do you mean you have the hole in the front lip of your oil pan, but your timing cover does not have the integral bolt (see thumbnails, below big pic) ?
          • Gary C.
            • April 1, 1998
            • 380
            Well thats interesting Wayne.
            My pan does not have a hole to install a bolt to the timing cover.
            • William C.
              • May 31, 1975
              • 6037
              Then you do not have a '65-early '66 pan.
              Bill Clupper #618
              • Gary C.
                • April 1, 1998
                • 380
                Yes I thought so. I dont mean to hijack Mark's post but where can you get a good repo 65 pan? LIC maybe?
                • R N.
                  • May 31, 2002
                  • 640
                  Interesting Wayne, if I read that right, my March '66 L72 should not have the center bolt or a hole in the pan?
                    • 43259
                    Kurt------
                    No, I believe the early style pan and bolt would still have been used at the time your 1966 was built.
                    • Gary J.
                      • April 1, 1980
                      • 1245
                      My late June car has the hole for the bolt
