Rocker arms - NCRS Discussion Boards
Rocker arms
  • Phil A.
    • April 30, 1982
    • 121
    Rocker arms
    Does anyone know when the "0" on hiperformance rocker arms was first used? Thanks Phil
  • Michael H.
    • January 29, 2008
    • 7477
    Re: Rocker arms
    Phil, I think it was some time in the early part of the 63 model year.
    • Ray K.
      • July 31, 1985
      • 375
      Re: Rocker arms
      Phil
      Michael is most likely correct or very close as I show that they entered the parts system in 5-64 under part #3843359, so production sometime in 1963.
      Also, about that same time, the hardened tip pushrods #3796243 became available.
      Ray
      • Clem Z.
        • January 1, 2006
        • 9427
        Re: Rocker arms
        Originally posted by Ray Kimminau (8917)
        Phil
        Ray
        the hardened tip push rods are hardened only on one end so always make sure the that tip is up. new ones have a blue stripe on the hard end and if you look close you can see the hardened insert that is not on the other end.
        • Michael H.
          • January 29, 2008
          • 7477
          Re: Rocker arms
          Phil
          Ray
          Ray,
          Just out of curiousity, I looked in my old July 63 printing of the parts book and the 3843359 is listed. It probably entered production several months prior to that time.
          I think the 3796243 pushrod was around during the latter part of 62 model year production.
          • Ray K.
            • July 31, 1985
            • 375
            Re: Rocker arms
            Michael
            I'm sure that you are correct. I just checked the history section to see when they actually referenced the change in part Numbers. The pushrod was earlier than the rocker arm. And good point to Clem - I should have said that only one end is hardened ( with a blue or black stripe) and that it goes up to the rocker arm.
            Ray
            • Bill M.
              • April 1, 1977
              • 1386
              Re: Rocker arms
              Originally posted by Michael Hanson (4067)
              Ray,
              October 1, 1962 parts book shows 3796243 for '62,'63 340 and 360.
              • Stuart F.
                • August 31, 1996
                • 4676
                Re: Rocker arms
                My L-76 built in July 63 has both. Just did a valve adjustment a month or so ago and noted appearance and condition. All is going well after 44,500 miles.
                Stu Fox
