'63-'64 Differentials - NCRS Discussion Boards
  • Gary R.
    • April 1, 1989
    • 1799
    As a service to fellow members I put together some photos of the 63-64 diff's because I often see questions on the early cars. A lot of guys don't know what was in there in 63-64 or what they may be looking at once they pop the cover off or go to buy one.
    As many know the 63-64 optional posi wasn't the best out there and many are long gone by now. I still see some but you can't rebuild them nor would you want to unless you just want the original weak posi?
    Here is a '63. It will bolt into any vette from 63-79 although in stock form is not recommended for most applications.
    The covers didn't have a date code like the later covers do. The side plug is larger and has a machine thread. The later covers use a 3/4npt thread. The vent is steel
    The top casting has through holes because it's thinner. This is a 63
    Here is a 64
    casting date on the LH side
    The front bracket hole is tapped 7/16-14, 65-79 had thru holes
    Inside the spreader holes are large on both sides. The later housings have 2 hole sizes.
    Here is an original Dana posi in a stone stock 64 I did. You can see the difference if you compare to a 1st or 2nd design Eaton posi found in the 65-79's. BTW,the 65-68 Eatons weren't much better in stock form,most I see are cracked.
    Here is a 1st design Eaton in a 63. This is also a 4 series case.
    The Ring & pinion and pinion yoke are the obsolete coarse spline. They also used a small crush sleeve because of a soulder in the pinion.
    Hope this helps answer those questions I often see.
  • Dan H.
    • July 31, 1977
    • 1369
    Re: '63-'64 Differentials
    Hi Gary, found my 64 has a 1st design Eaton, are the yoke and gears necessarily of the later design too? The ring gear is 3:36 dated 3/63. Looks like an old warranty job? Thanks!
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Gary R.
      • April 1, 1989
      • 1799
      Dan
      Chances are the original posi blew apart and someone installed the Eaton a long time ago. I would check it for cracks.If you have a 63 R&P then it's the obsolete coarse design. I found those into 65's.
      The side yokes, hard to say unless you have them out. If they have the center drill hole they're originals. The rebuilt ones use a flat face. The early side yokes are pretty good. I posted about those a couple of weeks ago. I've been able to reuse them many times. If you have yours out you can check them.
      • Dan H.
        • July 31, 1977
        • 1369
        Gary, the side yokes center drill hole, where would it be? Have pictures of when the differential was out, where do you check? Thanks,
        Dan
        • Gary R.
          • April 1, 1989
          • 1799
          Dan
          Here is that thread from a couple of weeks ago. I show the original yokes in it.
          https://www.forums.ncrs.org/showthre...85666&uid=6619
            • 15706
            Wasn't the first design Positraction - the one shown in the 1963 Corvette Shop Manual of Borg-Warner design/manufacture?
            • Dan H.
              • July 31, 1977
              • 1369
              Dan
              Thanks Gary, that's what I was looking for. I have the original side yokes, R & P gears. Was rebuilt about 15K ago and is smooth, no chatter, think I'll leave it alone and drive it!
              Dan
                Duke -
                That was a Dana piece.
                • Gary R.
                  • April 1, 1989
                  • 1799
                  Might as well, if you have a problem in the future you know what you have to deal with.
