'68 Wiper Motor - NCRS Discussion Boards
'68 Wiper Motor
  • Brian W.
    • September 30, 1990
    • 216
    '68 Wiper Motor
    Can someone tell me if this wiper motor is correct for a '68 built in mid-December '67?
    On the end of the motor is stamped Type C
    12 volt
    Under it and upside down is stamed 5044683
    ASS'Y
    The main body on the front side DELCO PRODUCTS
    - GM -
    On the back side DELCO PRODUCTIONS
    ROCHESTER.N.Y.
    MADE IN U.S.A.
    4918077
    • 43289
    Re: '68 Wiper Motor
    12 volt
    ASS'Y
    - GM -
    ROCHESTER.N.Y.
    MADE IN U.S.A.
    4918077
    Brian------
    Yes, it's a 1968 Corvette wiper motor. In fact, the GM #5044683 wiper motor assembly was unique to 1968 Corvettes.
    • Brian W.
      • 216
      Re: '68 Wiper Motor
      Thanks Joe, that's what I wanted to hear.
      The aluminum casting is cracked around one of the mounting bosses. Is this part common or will it be difficult to find. Any idea where I can get one?
      Brian
        • 43289
        Re: '68 Wiper Motor
        Brian
        Brian-----
        I believe the housings are the same for at least 68-72 but I'm not 100% sure. The housings were never available from GM as a separate part. You should be able to repair the one you have using Muggyweld rod.
