69 Front Caliper Dates - NCRS Discussion Boards
  • Chris H.
    • April 1, 2000
    • 837
    The front calipers have been removed from my 69 and I'm looking for the dates referenced in the Judging Guide. It says the "machined surfaces will contain a small date code".
    There are at least 10 machined surfaces on the caliper. Does anyone know where to precisely look?
    Thanks, Chris
    • 6954
    Re: 69 Front Caliper Dates
    Chris, look at the top of the calipers, I believe there next to the bleeder area or near by, get the glasses out there stamps are small.
      • 43263
      Thanks, Chris
      Chris-----
      The original calipers on my original owner 1969 have NO stamped date codes. I've looked them over THOROUGHLY and there are none to be found.
        • 11689
        Top surface.
        They are very, very small.
        • Chris H.
          • April 1, 2000
          • 837
          Thanks Patrick and Joe. Patrick, that looks like a cast surface versus a machined surface. On my calipers, there are Julian dates in the castings.
          Chris
          • Mark D.
            1984-96 Team Leader
            • June 30, 1988
            • 2165
            Patrick's PIC shows an aged machined surface of a caliper.
            Here is a broad view of the same area...
            And here is a date, in this case the 63rd day of 1970, IMO...
            Kramden
              • 11689
              Chris
              Mine is also painted to "look machined" by using silver paint cuz I don't want it to rust.
              Patrick
              • Jerry B.
                • August 31, 1994
                • 416
                How would you interpret 063
                • Chris H.
                  • April 1, 2000
                  • 837
                  Thanks Mark. Excellent photo. Chris
                  • Chris H.
                    • April 1, 2000
                    • 837
                    Ok, after some cleaning I found some numbers. 3 out of the four caliper halves that make up the front pair of calipers had a 3 digit stamp. I presume a Julian date for the calendar year. "332" for a car built on December 10th would be plausible.
                    I also found a "Y" stamp on each of the bottom of the caliper halves.
                    Chris
                    • Erik S.
                      • January 1, 2005
                      • 407
                      Hi Chris - looks like a 7 to me so 337?
