Power Steering Return Line ? - NCRS Discussion Boards
  • Peter M.
    • April 8, 2007
    • 570
    In the photo below, which fluid line (A or B) is the return line? Any help will be appreciated.
    • 6950
    Re: Power Steering Return Line ?
    Peter,( A) is the return line and(B) is the pressure line.
    • Peter M.
      • April 8, 2007
      • 570
      Thanks, Ed. So if I want to flush the power steering system, I disconnect line A and rotate the pump while keeping the reservoir full, correct ?
        • 6950
        Peter, anyway you do it will make a mess. what you can do is to make a cardboard sheild and point it toward a drain pan. and jack front wheels of ground if you have a jack and just turn the steering wheel from stop to stop with hose disconnected a few times then re- attach hose and fill system and start engine and turn wheel again from stop to stop a few times and then drain again.Just repeat until you get clear fluid. You'll need a few bottle of p./strg. fluid. Good luck
