I have heard lots of discussion about weather a C2 (K66) car should have a pilot hole or no hole drilled in the fire wall where ballast resistor would mount for Non TI Cars. Some have also stated there should be filler/puddy over the hole. What is correct???? I have what I believe to be an original 1966 427/425 with (K66) TI ignition. My car is an A-Body Car built in early March of 1966. There is a hole where the ballast resistor would mount that appears to never have been tapped with a screw, and there is no evidence of the ballast resistor bracket ever being on there. I also do have the clip under the driver side hood latch for the TI wiring. Any pictures of documented unrestored TI Cars would be greatly appreciated!!!
What about "NO ballast resistor" C2 cars (K66)
Re: What about "NO ballast resistor" C2 cars (K66)
Check out this link on a Nov 2008 thread:I have heard lots of discussion about weather a C2 (K66) car should have a pilot hole or no hole drilled in the fire wall where ballast resistor would mount for Non TI Cars. Some have also stated there should be filler/puddy over the hole. What is correct???? I have what I believe to be an original 1966 427/425 with (K66) TI ignition. My car is an A-Body Car built in early March of 1966. There is a hole where the ballast resistor would mount that appears to never have been tapped with a screw, and there is no evidence of the ballast resistor bracket ever being on there. I also do have the clip under the driver side hood latch for the TI wiring. Any pictures of documented unrestored TI Cars would be greatly appreciated!!!
https://www.forums.ncrs.org/showthre...65133&uid=2138- Top
