Re: 1971 454/425hp LS6 Heads - Uncertain Usage?
Joe, now I'm more confused than ever. Warren lists the dome height on a '70 LS6 piston as .390. Mine measure approx. .280. Again, my measuring was crude, but it's less than 1/16 more than .250, and appears to be about 1/32 more, which would be .250 plus .030.
I also just glanced at my LS7 pistons. They are stamped on the dome GM (above the part number instead of inline like I thought) 3963551. I said above that they came from a '70 LS7 crate, but actually I don't know what crate they came from, only that it was a factory LS7 long block, and they are open chamber design domes and are the taller ones, and the camshaft is the part number used in ZL1, 2nd design L88 & LS7...... 3959180 if I remember right (which is doubtful these days
What would be the source of Clem's post above saying the 550 piston shows as 11.25:1 70 Chevelle if that isn't a valid number for that application?
