I started with the dash lights becoming to dim and not being able to adjust the light intensity and then no dash lights. I surmised that I was dealing a bad/worn light switch rheostat. I purchased a new switch and last night I began the task of replacing it. But before I started I noticed that the fuse was blown to the parking lights. I decided to replace the switch anyway. Replacement was easy and everything worked. Before I put every thing back together I decided to leave the lights on while I screwed the dash back together. When I started, I slowly pushed the dash back in place and the fused popped on the dash lights. I looked around but the only thing that I can see is that the one of the bulbs to the tachometer is out of the socket( what a PITA its going to be to get it back in). Has any one had a short in the dash lights. If so how did you repair or does anybody have any ideas where to look?
Thanks for your help in advance
Joe
PS Any short cuts on the dash lights?
Joe
