Ring and pinion gear id, 64 Posi - NCRS Discussion Boards
  • John R.
    • November 1, 2005
    • 433
    64 differential has the following stamped numbers:
    Ring, OA 3756448 12:37 GM 3 67
    Pinion, 3819184 GM 1 12:67 12:37
    Assembly stamp on differential is CB 5 7 64 with AB on the other side, and casting date of C94.
    Has a Dana Posi with the following:
    Casting date: 30, guess julian date of Jan 30th
    Stamp on unit is: C 32324 and C21064
    Has a large 24 cast into the side along with PAT 2966076
    Is this a 3:08 or 3:36??
    • 43220
    Re: Ring and pinion gear id, 64 Posi
    John------
    It's a 3.08:1 ratio used for 1963-64 Corvettes. The gearset was known as GM #3822991.
    • Chuck G.
      • May 31, 1982
      • 2034
      The 12:37 stamped on both items is the giveaway.
      37/12 = 3.08
      You'll find similar ratio stamps on all Corvette rear gears (ring and pinion)
      Chuck
      • John R.
        • November 1, 2005
        • 433
        So, the CB denotes 3.36, but the gears have been replaced to convert to 3.08??
        • Larry M.
          • January 1, 1992
          • 2691
          37/12 = 3.08
          Chuck
          Or just COUNT the teeth and then divide. Works every time.
          Larry
          • Wayne M.
            • March 1, 1980
            • 6414
            ...It's a 3.08:1 ratio used for 1963-64 Corvettes. The gearset was known as GM #3822991.
            And the original 3.36's (CB code) were changed to the 3.08's sometime after 12-67 (the latest stamped date, which is on the pinion, in your situation). I don't know enough about Dana posi cases to guess at whether it was also changed, along with the R & P. The Dana 3 and 4-series positraction cases were definitely still available from GM at that time.
            • Chuck G.
              • May 31, 1982
              • 2034
              Gears get switched in cases all the time.
              I have the entire original 4.11 rear pumpkin from my 63 on the shelf.
              In the car is a 3.08 case, stamped CJ I believe. Don't remember the date sometime in 1963, but in that case is a set of 3.55 gears.
              I still have the original pumpkin in my 69. It was a 3.08, but when I rebuilt it, I put in 3.36 gears.
              Chuck
