would like info on rear of instrument cluster. broadcast number and speedo and tach numbers for a 66 L72
66 L72 instrument cluster info
Re: 66 L72 instrument cluster info
Should be exactly the same as this tag on the back of the last 396 (Aug 2nd 1965). Cluster ink-dated July 26 1965.
The only difference in the gauges would be the scale and color zones on the temp, and the endpoint (240 w/no color for '65, vs. 250 with color zones, for '66).
- Top
I notice Long Island Corette lists many dash cluster stickers; unfortunately, they don't give the letter codes for the various speedo and tach combos.
Can you tell us what these two latter part #s are on your LD sticker ? Maybe we can work backwards to what engine and option(s) this applies to.- Top
This issue came up a few months ago. Do an inquiry on the subject and I believe you'll find a fairly complete list of the numbers for the various combinations- Top
6455367 is the standard '65-7 speedo w/o '67 speed warning (U15).
6412222 is the 5300 RPM redline (base engine in '66-7).
6412522 is the 6000 redline ('65-7).
From P&A30B Corvette catalogs, Gr 9.750 and 9.761.- Top
Carl, Here's that (67) thread from a while ago, it may help....Rich
https://www.forums.ncrs.org/showthre...=7409#poststop- Top
