Source for SBC .020 steel shim head gasket ? - NCRS Discussion Boards
  • Tracy C.
    • July 31, 2003
    • 2739
    Felpro offers a shim gasket at .015 thk and Mr Gasket offers one advertised at .02 but it measures closer to .030. I need one in the .019 - ,020 range.
    Anyone?
    thanks,
    tc
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Source for SBC .020 steel shim head gasket ?
    Anyone?
    thanks,
    tc
    remember the compressed thickness is greater than the thickness of the material.
    • Tracy C.
      • July 31, 2003
      • 2739
      OK..anyone with a idea of what the .015 felpro shim would end up being after installation ? I agree, the embossed beads would not likely smash completely flat.
      • Clem Z.
        • January 1, 2006
        • 9427
        .005 difference in thickness means about .1 difference in CR. try the fel pro website for the compressed thickness
        • Clem Z.
          • January 1, 2006
          • 9427
          checked the fel pro catalog and that is the compressed thickness .015
          • Tracy C.
            • July 31, 2003
            • 2739
            Yes...and the shim gasket actually measures .0155 on the edges.
              • 15706
              Most gasket thickness specs are of the gasket compressed when installed with proper torque.
              Shim type gaskets will compress to the thickness of the original material, so their compressed thickness can be measured on an unformed portion of the material prior to installation.
              I have a reference to a Victor Reinz stainless steel shim gasket - .020" - 1178SSB.
              • Tracy C.
                • July 31, 2003
                • 2739
                Thank you Duke !
                That part is as close as my local Auto Zone...
                You have email.
                tc
                • Clem Z.
                  • January 1, 2006
                  • 9427
                  these are close to the original GM 336 stainless gaskets and are very stiff. i would be careful using them if the heads and block are not trued. also i would use high temp aluminum paint as a sealer.
                  • Tracy C.
                    • July 31, 2003
                    • 2739
                    Thanks Clem,
                    tc
                    • Michael F.
                      • June 4, 2009
                      • 291
                      My deck and head surfaces were true.
                      I used a light coat of Permatex copper gasket sealer on my .015 shim gasket.
                      Is that not a good choice for a sealer?
                      • Clem Z.
                        • January 1, 2006
                        • 9427
                        i always used high temp aluminum paint and never had a problem even in 13:1 CR race engines. some of the shim gaskets now sold have a rubber type coating and you should not use any sealer of any kind. torquing the bolts in steps of 10# at a time after starting at 25# will be the best way of not having gasket failure.
                        • Michael F.
                          • June 4, 2009
                          • 291
                          Yes, Viton coating.
                          Woops! Mine are. I don't think the sealer will hurt anything. I hope.
                          They re-torqued well and no leaks.
                          • Tracy C.
                            • July 31, 2003
                            • 2739
                            Michael,
                            Do you have a set of feeler gages to determine your final compressed thickness?
                            tc
                            • Timothy B.
                              • April 30, 1983
                              • 5203
                              Tracy,
                              If you can find a set of GM 3830711 shim gaskets they measure at .022 thick, I picked up a NOS set and have measured them myself.
