Looking for help identifying which crank is correct for the 427, 4351, 2 bolt main, 67 corvette block? Does it have a part number stamped on it, if so what is it? Thanks. Chuck
What crank is correct for a 427, 4351 2 bolt main block?
Tags: None
Re: What crank is correct for a 427, 4351 2 bolt main block?
6223 is one number use on 427 forged cranks- Top
The most common 427 crankshaft forgings of the period were 6223 or 3856223. There were a few others that may have been used, but these are the most common.In Appreciation of John Hinckley- Top
Joe, thanks. That's the number I'm finding also. Chuck- Top
The 3904351 block was produced in both 2- and 4-bolt versions; the wording in the original post ("427, 4351") refers to the 4351 casting number, not 435hp. The 435hp version (L-71) was indeed a 4-bolt block, and the 390 and 400hp versions were 2-bolt blocks.- Top
Pic of the 6223 casting number on a 2-bolt '65 961 block, in post #17 of this old thread.
https://www.forums.ncrs.org/showthre...crank&uid=2810
Thanks! Chuck- Top
