Installing Front Steel Brake Line - NCRS Discussion Boards
  • Tom F.
    • September 20, 2009
    • 66
    I'm replacing the steel brake lines on my "62" with prebent lines and question what is the best and easiest way to install the front crossover line. Will I need to remove the shroud, fan clutch an fan?
  • Mike E.
    • February 28, 1975
    • 5152
    Re: Installing Front Steel Brake Line
    Best and easiest, or best or easiest. Easiest--leave everything on, and force it in, bend it, unbend it, until you have it.
    Best---take off the shroud for sure. Much less chance of dings, scratches, etc.
    • Tom F.
      • 66
      Thanks for your input;
      I did remove the fan shroud, fan clutch, fan and both upper and lower radiator hoses. Once I could see what I was doing I was able to get the the lines onto the top of the frame and then onto the brake block.
