62 - Correct Rocker Panel mounting bolts? - NCRS Discussion Boards
  • Anthony P.
    • June 27, 2010
    • 485
    I have looked in the AIM, section A, sheet 4, as well as the archives, and I am still unclear to the correct bolts used to mount the lower portion of the rocker panel to the car.
    Even though I have the following part numbers from the AIM, I am not sure what they are:
    Bolt = 9417692
    flat washer = 120392
    Lock washer = 120380
    Nut = 134551
    Does someone have a picture?
    Also, I see that Paragon, Zip and others do have bolts. Does anyone know who carries the correct bolts/nuts?
    Tony
  • Doug F.
    • November 1, 1983
    • 322
    Re: 62 - Correct Rocker Panel mounting bolts?
    the unmolested low mileage car i have has 1/4-20 x 3/4, standard 7/16 head with no markings
    • Anthony P.
      • June 27, 2010
      • 485
      Doug,
      Is the head on the bolt just a typical hex head?
      Tony
      • Doug F.
        • November 1, 1983
        • 322
        yep, plain old hex head
