May 62 vette- Which Coordinator is correct? - NCRS Discussion Boards
  • Anthony P.
    • June 27, 2010
    • 485
    Which coordinator is correct for a May 1962 vette, if either? The part number is very hard to read, but they both appear to have 88693-3, but I am not 100% sure since they are quite worn.
    Note that on #1, one of the nipples (right front) is broken off.
    The complete Washer bottle assembly is shown in the AIM section 582, but it does not show the coordinator number.
    Tony
  • John F.
    • March 23, 2008
    • 2418
    Re: May 62 vette- Which Coordinator is correct?
    Here is my original! Car #00029. Hard to see the number and it is full of water. Mine is like #1 in your picture.
    • Terry B.
      • December 6, 2010
      • 73
      Your #1 photo matches mine.
      • Anthony P.
        • June 27, 2010
        • 485
        Thanks for the info. I was hoping it would be #2, since the nipple on #1 is broken.
        In any case it looks like I can pull the rivets and swap the bases since both bases are identical.
        Tony
        • Mike E.
          • February 28, 1975
          • 5141
          The one on the left is correct for all 62's; there was no running change during the 62 model year.
          • Anthony P.
            • June 27, 2010
            • 485
            Thanks Mike.
            Since the bases on both units are exactly the same, I just swapped the top to the one without the broken nipple.
            Do you have any idea what the one on the right would go to?
            Tony
            • Jay M.
              • December 1, 1991
              • 39
              • Anthony P.
                • June 27, 2010
                • 485
                Jay,
                Attached are the pictures of the lid after it soaked in cleaner for 24 hrs. It was mostly black previously. Note that the part number on the bottom of the lid is: P89-4446-1
                To the best of my knowledge this is an original lid. Agree?
                The coordinator that was on this lid, was the one on the left in my original picture. I had the other one in a box of stuff and since the one on the lid had a broken nipple I was going to swap them out.
                Tony
                • Jay M.
                  • December 1, 1991
                  • 39
                  The lid you have pictured is perfect for your 62.
                  Jay
