'67 Ballast Resistor - NCRS Discussion Boards
+ More Options
Posts
  • Peter F.
    Infrequent User
    • April 16, 2009
    • 10
    I have a '67 big block 390 that has a white ceramic ballast resistor mounted on the firewall. Is this correct? I thought that the resister only came on the small block. If I remove the resistor, where do I make the current wire connections? I am getting my car ready for WildWood and would appreciate any information to correct the situation.
    Thank you
    Peter
  • Donald O.
    • May 31, 1990
    • 1593
    Re: '67 Ballast Resistor
    Thank you
    Peter
    Since you said it is not a TI car, the white ceramic ballast resistor is correct. SB or BB the same BR was used.
    DonO
    • Bill I.
      • January 29, 2008
      • 554
      I agree. Don't forget, there some that are Fuddging" the issue to look correct.
