The subject car is a 1967 small block (L79) with C60 (i.e., one regular LH horn mount, different RH horn mount)
Question: What are the correct Dimensions, Headmark, Grade and Head Type (indented or regular hex) for GM bolt # 3848408?
This bolt is used to secure the Horns to the Radiator Support and also used on the small block starter motor brace (1967 only). Bolt 3848408 appears to be a production-only part number. TDB archive search only turns up two Threads containing this part number, but neither was conclusive regarding Hex-head type (regular hex or indented hex), headmarks, grade or measurements.1967 AIM:
1968 AIM: Bracket
1969 AIM:
1968 AIM: Bracket
1969 AIM:
) and found multiple examples of midyear Corvette horn bolts on the usual auction website, offered by someone who ought to know these bolts. There are both Grade 2 (no lines) and Grade 5 examples shown. All appear to be 5/16-18 x 1/2", all with attached external tooth (square-tip) washers, and all with REGULAR hex-head (not recessed or indented). Grade 2 examples are shown with "TR" and "RBW" (two different styles) headmarks, and a Grade 5 "RSC" (like my starter motor brace bolt).
