63 Ride height - NCRS Discussion Boards
63 Ride height
  • Michael G.
    • November 12, 2008
    • 2158
    63 Ride height
    The blue car has a new rear spring (along with everything else), I'm wondering if it looks a bit high in the back? I've stuck the black one in there for comparison purposes (the black one's got radials, so it might be lower overall.
    I haven't driven the blue one yet, I suppose it might settle down a little. What do you guys think?
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 63 Ride height
    The ride height specs are in your AIM. The AIM describes how to correctly measure both front and rear. The measurement is taken from 2 points on the suspension at all corners, with the difference being the ride height. This technique allows for various tire heights... eliminates that variable.
    If the spring is new there may be some settling over time.....
    • Timothy B.
      • April 30, 1983
      • 5198
      Re: 63 Ride height
      Michael,
      The car will settle down after you bounce it around a bit. What type of spring did you use on the rear?
      Your cars look very nice..
      • Michael G.
        • November 12, 2008
        • 2158
        Re: 63 Ride height
        Thanks Steve, I'll look in the AIM
        Tim, the spring is an Eaton, standard ride height, 9 leaf. I had to paint it grey and change the liners. I've been looking for a nice used original for a while, without much luck, so I decided to go with the repro until one shows up. I'll probably get some originality deducts on the spring when I put it through judging this Spring and Summer.
        Thanks for the compliments. The black car is my driver, the blue car is completely fresh, with new lacquer, etc. It got Duntov, Boomington Gold and Triple Crown in the early nineties, but needed a freshening after sitting with minimal driving for twenty years.
        Mike
        • Bob R.
          • June 30, 2002
          • 1595
          Re: 63 Ride height
          By just changing the rubber bushings the height will increase about an inch. My car did but after a short amount of driving it will go down most of that inch. I'm sure the spring will settle a little also.
            Re: 63 Ride height
            Mike -
            I put an Eaton 9-leaf in my '67 about eight years ago - it sat about 3/4" high at the beginning, and settled out nicely after about 100 miles.
