63 T-10 Question - NCRS Discussion Boards
63 T-10 Question
  • Henry A.
    • May 31, 1990
    • 107
    63 T-10 Question
    Rebuilding a T-10 for a 63...is the spline or output shaft a 16 tooth or a finer 24 to 26 tooth?
    Henry Atsma
    54 White/Red
    63 Red/Black SWC
    67 Elkhart Blue/Black BB Roadster
    91 Black/Red ZR1
    96 CE - LT4
    07 Red/Tan
    • 43246
    Re: 63 T-10 Question
    Henry-----
    It's the course spline. I don't recall if it's 16 teeth but it's definitely not the 26 spline. The 26 spline was used from 1965 to 1967 as well as 68-70 with manual transmission. 32 spline was used for 68-70 with THM as well as most 71+.
    • Henry A.
      • May 31, 1990
      • 107
      Joe, Thanks for the quick response. This confirms what I and the rebuilder thought. Your confirmation helps to rebuild it correctly.
      I really appreciate your help.
      Henry Atsma
      54 White/Red
      63 Red/Black SWC
      91 Black/Red ZR1
      96 CE - LT4
      07 Red/Tan
      • Ray K.
        • July 31, 1985
        • 375
        Henry
        If the trans is definitely a Borg Warner T-10 - it will have the coarse 16 spline out put shaft.
        If the trans should happen to be a Muncie - it will have the fine 26 spline out put shaft.
        Ray
        • Timothy B.
          • April 30, 1983
          • 5193
          Ray,
          I believe the Muncie transmission in 1963 used the course spline main shaft, fine spline started in 64.
          • Ray K.
            • July 31, 1985
            • 375
            Timothy,
            My P & A catalogs (65 -67-69 ) say otherwise; #3868728 would be the fine spline yoke.
            Ray
            • Norris W.
              • December 1, 1982
              • 684
              If it's really a '63 transmission the front input shaft cover will be smaller in outside diameter where it centers in the bellhousing. This is a one year only transmission and makes the bellhousing one year only also.
              • Eric D.
                • February 1, 1992
                • 42
                Muncie 4-speeds never used a course spline(16) out put main shaft, 27 spline 1963 1/2 thru 1970, 32 spline 1971-74 and 1970 BB Chevelles...
                Hope this helps... Eric
                  • 43246
                  Originally posted by Ray Kimminau (8917)
                  Timothy,
                  Ray
                  Ray-----
                  Yes, 1963-64 with Muncie did use a 26 spline output (main) shaft. However, the transmission yoke was not originally GM #3868728. The original yoke was GM #3832678. The 65+ yoke, GM #3868728, replaced it for SERVICE in January, 1965.
                  • Timothy B.
                    • April 30, 1983
                    • 5193
                    I apologize if I gave bad information, for some reason I thought all 63's used a course spline main shaft even the first Muncie transmissions.
                    • Ray K.
                      • July 31, 1985
                      • 375
                      Joe,
                      Thanks for the update on the original 63-64 yoke part number, my books are limited from the early 60's.
                      Ray
