58 carpet Vs. seat frame - NCRS Discussion Boards
  • Brad H.
    • August 12, 2007
    • 724
    Has anyone got any good pictures of there carpet going in and how it works around the seat frame work, and the bolts showing? Thanks, Brad.
  • David S.
    • December 1, 1982
    • 310
    Re: 58 carpet Vs. seat frame
    Hi Brad,
    If nothing else we will get your post back on top.
    I am attaching a few pictures from my 57 bowtie car that may help.
    I would think that a 58 would be the same install.
    Dave
    • Brad H.
      • August 12, 2007
      • 724
      Hi Dave, Thanks for the reply, the AIM says that carpet covers the rails, is that mean the carpet runs over the top of the bolts and up against the sides of the feet on both sides, am not getting this, does this also mean that the whole frame work would be installed so as to but the carpet up against and over the bolts and feet? Thanks, Brad.
      • Terry D.
        • May 31, 1987
        • 2691
        Brad
        The answers are yes and yes. The frame is under the carpet not on top.
        • Brad H.
          • August 12, 2007
          • 724
          Hi Terry, Is the carpet left loose at these areas so the frame can be slid into poisition then cut around feet, or is frame set on top of carpet (still loose) marking feet then cut and then frame installed, then carpet glued in place around and over bolts? would like to see this procedure, pics or video would be best. Thank you again, Brad.
          • David S.
            • December 1, 1982
            • 310
            Hi Brad,
            I am attaching a few more pictures for you.
            Bolt the frame down to the floor and bring the carpet up over the bolt heads upto the mounting brackets. Do not glue the carpet near the frame so you can get to the bolt heads
            Dave
            • David S.
              • December 1, 1982
              • 310
              Sorry Brad I forgot this one.
              • Jorn J.
                • October 21, 2008
                • 142
                Hi Brad
                Paragon has some videos about carpet installation on YouTube which I think are good.
                Jorn
                • Brad H.
                  • August 12, 2007
                  • 724
                  Thanks again guys for your information. Brad.
