half shaft - NCRS Discussion Boards
half shaft
  • Scott S.
    • February 4, 2010
    • 52
    half shaft
    Hi Guys, I have a question about the half shafts,(72) Is the rearend side biger then the tire side?. And dose it matter whitch end go's in. thanks Scott
    • 6940
    Re: half shaft
    Scott, If the axles are assy'd there is one side with a flange(Wheel side) and one side with just the u-joint cups(rear end side).There is no inner or outter side.unless you marked them before dissay. I Believe the factory did have some paint marks for assembly.once there gone you on your own. but I have yet to see a problem if you mix them up.
    • Scott S.
      • February 4, 2010
      • 52
      Re: half shaft
      Ed, Thanks, I did forget to mark thembut I havent had any problums yet,but I keep hearing a noise and thought that was it. Thanks agen
      • Norris W.
        • December 1, 1982
        • 683
        Re: half shaft
        Originally posted by Scott Spillar (51338)
        ..................but I keep hearing a noise and thought that was it.
        You didn't lose a needle bearing over the end when assembling did you?
        • Scott S.
          • February 4, 2010
          • 52
          Re: half shaft
          Im not sure,I did it last year and it did'nt seam any thing came apart. It seams to happen when I drive long distances. I guess any thing is posable at this point.
          • Rich W.
            • March 13, 2011
            • 146
            Re: half shaft
            Scott..what type of noise is it..a u joint noise usually happens all the time..is it possible that the rear fluid needs changed..additive and all..
            • Scott S.
              • February 4, 2010
              • 52
              Re: half shaft
              Hi Rich,It started to make a sqweeking noisethen a loud KLUNK, like if the U-joint was dry, I thought the weel or rearend was going to come apart but it never seamed to effect the proformance.But I cant check it right now the motor is geting rebuilt. Whats your thoughts?.
              • Rich W.
                • March 13, 2011
                • 146
                Re: half shaft
                Scott if it is a squeek noise that gets faster with road speed then chances are it is a u joint..unless you have a brake pad squeeking..which can happen..easy to check if it goes away when you hit the brakes..well I guess once you get the motor done..what u joints did you use..it is a massive debate everywhere at which type to use..non grease or grease style..to be true to stock I believe all were non grease..it may also be one of the rear bearings going out also..easy to check them without a motor though..they can clunk if they are falling apart..I have learned over the years that even though you just replaced it ..it doesn't mean that the parts used wont fail earlier than they should..so it could be the u joint..it will just take some diag to put it all together..
