AC AIM Questions - NCRS Discussion Boards
AC AIM Questions
+ More Options
Posts
  • Mark P.
    • December 1, 2004
    • 62
    AC AIM Questions
    This is a 67 small block AC car and I have two questions.
    1. Page G321 Sheet D6 shows the expansion valves J clamp attached to the suction line outlet. Was a clamp used to secure the J clamp or is the clamp merely held in place by the insulating material. The attached photo shows the clamp that was used to secure the incorrect "corkscrew" bulb, but this green clamp does not seem to be compatible with the J style clamp.
    2. The water shut off valve is shown with its outlet in the up position on page G319 sheet D4. While Page 323 sheet D7 shows this valve with the outlet facing down. Which is correct?
    Mark
