Spring Ring Battery Cables - NCRS Discussion Boards
  • Mark P.
    • December 1, 2004
    • 62
    I getting ready to install a new pair of spring ring battery cables. In order to compress the spring I was just going to use a pair of channel locks. Is this the appropriate tool to use or did GM have a specific tool for installing the cables?
    Thanks---Mark
  • Carl N.
    • April 30, 1984
    • 592
    Re: Spring Ring Battery Cables
    Mark,
    I have used a small pair of channel locks for years without any problems,
    keep them in the glove box in case I ever smell smoke!
    Carl
    • Joe R.
      • May 31, 2006
      • 1822
      Originally posted by Carl Nicholl (7368)
      Mark,
      Carl
      Carl,
      To each his own,but wouldn't a knife switch disconnect from NAPA be faster and easier? As an added bonus, you get extra judging points!
      Joe
      • Mark S.
        • October 22, 2006
        • 35
        Be careful not to over do it with the pliers. The directions say to expand the spring rings as little as possible.
        • Bob H.
          • July 31, 2000
          • 827
          There are special pliers specifically for the spring rings.
          • Carl N.
            • April 30, 1984
            • 592
            Joe,
            Agree, but you still have a spring connection on one post.
            I place the spring connector on the post and carefully expand the opening till it slips down on the post - that's the reason I use a small pair of pliers to not be to agrssive !
            Carl
            • Mark P.
              • December 1, 2004
              • 62
              Thanks for your responses. I will go with one knife blade and the gentle use of a pliers on the remaining spring.
              Mark
