Testing 63 Headlight Switch - NCRS Discussion Boards
  • Greg W.
    • August 31, 2005
    • 117
    Can you test the switch that turns on and off the headlights?
    They were working before I replaced the dash and rear harness, now they don't. The parking lights, tail lights, turn signal, dash, courtesy works, just no headlights. Even the warning light works. All the wiring is new but the switch and the hi/lo beam switch.
    When I reassembled the cluster and inserted the knob it was very difficult to get back in. Could I have broke something in there?
    Thanks again for any help.
    Greg
  • Philip C.
    • December 1, 1984
    • 1117
    Re: Testing 63 Headlight Switch
    Greg
    Hi Greg, check that the plug on the dimmer switch didnt back off. Phil 8063
    • Jack H.
      • April 1, 1990
      • 9906
      And that you've actually got juice coming out of the dimmer switch... These switches can/do age to the point that the internal contacts get flakey...
      About half of those I harvest from scrap yard cars require being opened up, cleaned and lubricated.
      • Greg W.
        • August 31, 2005
        • 117
        If the power is getting to the parking lights and I can dim my dash lights, does that not imply that the power is coming out of switch?
        Greg
        • William C.
          • May 31, 1975
          • 6037
          Yes, but not that it is making it thru the foot operated dimmer switch, or even that the three way connection has been made at the foot operated dimmer switch.
          Bill Clupper #618
