WCFB Drip Question - NCRS Discussion Boards
WCFB Drip Question
  • Bob B.
    • March 1, 2003
    • 831
    WCFB Drip Question
    Hi all,
    I have a WCFB that doesn't leak on the outside but, when hot, it drips from the squirter/pump jet and from the booster venturi thing on either side in the middle of the bores. At the same time, the gas level in the fuel filter bowl changes.
    I am thinking adjusting the float may be the answer, but I wanted to check with the experts first.
    Bob
  • Gene M.
    • April 1, 1985
    • 4233
    Re: WCFB Drip Question
    Bob, the most common problem you have is caused by a bad leaking inlet seat. The leak stops once the pressure has releases and the valve is not fighting the fuel pressure.
    Replace fuel inlet seat and reset float level and your problem will most likely go away.
    • Stuart F.
      • August 31, 1996
      • 4676
      Certainly a needle/seat is the first place to look. You didn't say if it was just on the primary side or in both primary and secondary. If the latter is the case, then one sould suspect dirt contamination of the needle/seats.
      Stu Fox
      • John L.
        • February 20, 2009
        • 186
        Bob
        It could just be heat into the fuel after shutdown,... this is common if the float (front) is set to high. BUT (1) don't overlook a float that is going bad (leaking) and (2) best to use only an all brass needle and seat like orignial.
