Re: stripped bolt through sombrero
Solid carbide drill bit should go thru the grade 8 bolt with no problem. Step drill starting with an 1/8 and work your way up to tap drill size. Drill RPM should be slower.
Another way that nobody said is to break the welds of the sombrero and plug weld in a new one using a MIG.
The only thing I don't like is having a torch in the area any where next to the gas tank.
