Horsepower TV - NCRS Discussion Boards
Horsepower TV
  • Gene M.
    • April 1, 1985
    • 4232
    Horsepower TV
    Did you guys catch the Horsepower TV show over the week end. It was the only one I could say was real good. They went thru the pocket porting and cleaning up of SB Chevy cylinder heads.
  • Robert E.
    • April 1, 2004
    • 398
    Re: Horsepower TV
    Certainly one of the better episodes.
      • 15706
      Re: Horsepower TV
      The single best way to make "more power" is to massage the heads. Leave everthing else OE and the engine will look OE, idle like OE, and have the same general operating behavior up to about 4000 revs, but above that it will keep pulling strong to the redline or above.
      Figure about 10-15 percent more top end power, and no only does peak power improve, but the peak power "sweet spot" improves by extending the useable power range another 500-1000 revs.
      This applies to base, SHP, and FI engines as long as they have full dual exhaust systems.
      Unfortunately, the single catalyst system that began in 1975 will not respond very well to any internal changes. These exhaust systems have so much backpressure that pumping loses eat up most of the internal flow improvements that make more power with a low restriction exhaust. The pre-catalyst Corvette exhaust systems were good (2" pipes or 2.5" on big blocks) to very good (2.5" pipes with a small block).
      The best OE exhaust systems only generate about 3 psi backpressure with a massaged SHP small block - and up to 6 with a massaged SHP big block which is getting a bit restrictive.
      Dave McClellan in his book stated that the single catalyst exhaust added about half an atmosphere backpressure - that's about 7.5 psi - and when you end up with 10-12 or more psi backpressure the parasitic pumping power is HUGE, which is why seventies vintage Corvettes had such lackluster net power ratings and can't be significantly improved without adding a much lower restriction exhaust system.
      • Stan E.
        • April 30, 1991
        • 383
        Re: Horsepower TV
        You've got my interest up on the old 461x head. I think I'll put one of these on one of my flow benches and fool with it . Can you expect to pull 150 CFM w/1.94 intake @ 28". What are good numbers on these heads ? stan 19259
        • Joe R.
          • May 31, 2006
          • 1822
          Re: Horsepower TV
          Gene,
          Thanks for the tip. I watched it yesterday and really enjoyed it! I think I will buy the DVD since my DVR has no setting for "keep this show forever."
          Joe
          • Ray G.
            • May 31, 1986
            • 1189
            Re: Horsepower TV
            Thank you Duke Williams and all for explaining the advantages of cylinder head porting.
            Ray
            I hope you dance
              • 15706
              Re: Horsepower TV
              150 CFM? You're talking about the exhaust side, right?
              See the Fall 2010 Corvette Restorer. There is a table of head flow data for Flint-built and massaged 461 and 462 heads. I don't have any data for 461X, but my expectation is that the slightly larger port volume will flow about the same as 461/462s, all in OE form, but might be better when equivalently massaged and may outflow 2.02/1.6" 461/462s even with the original 1.94/1.5" valves.
              BTW, I NEVER recommend increasing the valve sizes if the heads originally have the 1.94/1.5" valves. The increased propensity for the heads to crack between the valve seats far outweights the marginal increase in flow.
              What kind of flow benchs do you have?
              • Dan M.
                • March 6, 2009
                • 157
                Re: Horsepower TV
                Could you post a link to the DVD, please?
                • Joe R.
                  • May 31, 2006
                  • 1822
                  Re: Horsepower TV
                  Dan,
                  Here you go:
                  Joe
                  • Paul J.
                    • September 9, 2008
                    • 2091
                    Re: Horsepower TV
                    Originally posted by Joe Raine (45823)
                    Gene,
                    Joe
                    If your DVR is through the cable company there is a "lock" feature that allows you to keep the recorded program forever. You designate the program that you want to keep, and it will not record over it or delete it from the queue.
                    • Joe R.
                      • May 31, 2006
                      • 1822
                      Re: Horsepower TV
                      Paul,
                      Yeah, I think my old DVR through Dish Network had that feature. I have U-Verse now, I don't see any such on-screen selection. This is the first time I have missed it.
                      Joe
                      • Roger W.
                        • January 29, 2008
                        • 569
                        Re: Horsepower TV
                        I use an old fashon VCR to record. I will save this episode.
                        • Joe C.
                          • August 31, 1999
                          • 4598
                          Re: Horsepower TV
                          Click on "Chevy" under "Cyl Head Flow @ 28 inches water column", scroll to 461 cylinder head.
                          I know someone who achieved 220/195 @ 0.5 and 224/201 @ 0.6 with 1.94/1.5 461's. Those are impressive flows, and the heads were ported beyond the pockets. I achieved 255/208 @ 0.6 with 2.02/1.60 461's after I fully ported them and opened the inlet runners to nearly 180cc's.
                          • Stan E.
                            • April 30, 1991
                            • 383
                            Re: Horsepower TV
                            Joe Ciaravino, Those are very impressive numbers. I guess the Chevy S/B has had more attention than the human heart. Thanks much stan 19259
