C1 front engine mounting - NCRS Discussion Boards
  • Rod K.
    • 445
    Can someone please give me the outside diameter of the thick flat washer (103343) used on the bottom of the front engine cross mount to frame tower bolt, between the bolt head and lower rubber cushion. I believe the top washer is 1-3/8 OD. Thanks in advance.
  • Rod K.
    • 445
    Re: C1 front engine mounting
    Any help?? Thanks.
    • Erich C.
      • January 31, 2007
      • 137
      The lower washer on my '62 measures 1-1/8" OD. The upper washer measures 1-3/8" OD. I don't know if there were any changes from '57 to '62 but my AIM shows a pt. # of 103342 for the lower washer.
      Last edited by Erich C.; April 5, 2011, 01:46 PM. Reason: website posted wrong message
      • Rod K.
        • 445
        Perfect, Eric. P/N for '57 is 103343, but the size is about what I expected. Thank you very much for the help.
        Still would still like to confirm size for a '57, p/n 103343.
        • Dan D.
          • November 5, 2008
          • 1323
          On my 57, top washer is 1-3/8, bottom is 1". But I would not guaranty mine, as it had a NOM when I bought it. -Dan-
          • Rod K.
            • 445
            Thanks, Dan. That fits with one washer I wasn't sure belonged on mine.
            BTW, Erich & Dan, do the nuts on yours have the dimples? Erich, what P/N is shown in the '62 AIM for the nut? Thanks for the help.
            • Bill M.
              • April 1, 1977
              • 1386
              Mine is known original '59. Bottom is 103343, 1 in. in diameter.
              • Erich C.
                • January 31, 2007
                • 137
                Dan,
                The nuts on mine have 2 dimples per nut. The P/N for the nut is: 3746699
                Erich
                • Rod K.
                  • 445
                  Originally posted by Erich Cornely (46879)
                  Dan,
                  Erich
                  Thanks, Erich. Mine (P/N 3695966) have no dimples, so it appears a change was made between '57 & '61-'62. Good to know.
                  • Rod K.
                    • 445
                    Good confirmation, Bill. Thanks.
