Heater Control Valve 59 C1 - NCRS Discussion Boards
  • John F.
    • January 1, 2000
    • 155
    I bought this replacement heater control valve (right) and it doesn't have the "coil". I believe the left side pic to be original but not sure. Do I need the coil sensor? I've search a few threads and have found pictures of them on later C1 models. thanks!
  • Bob H.
    • July 31, 2000
    • 827
    Re: Heater Control Valve 59 C1
    The one with the coil is the way they came from the factory. The replacements, although not correct in appearance, work correctly without it.
      John -
      The original design with the capillary tube appears to have been a (primitive) attempt at constant temperature modulation, which apparently didn't work out very well and was deleted from the Service replacement valves.
      • John T.
        NCRS Financial Officer
        • January 1, 1983
        • 293
        You do not need the capillary tube for function. You do however need it for judging.
        Hope this helps.
        John
