62 Frame mounting side rail shim/cushion location? - NCRS Discussion Boards
  • Anthony P.
    • June 27, 2010
    • 485
    Please refer to the attached picture.
    1. Where is the Rubber shim located that is on the outer side rails? How far from the front or back bracket is it?
    2. The AIM document shows 7 rubber shim locations including one on the rear frame cross member. Is there just one shim on that cross member? is there an 9th shim somewhere?
    3. On the shim that goes on the cross member. The diagram indicates that it is on a lip on the rear of that frame member. Is it actually on the top, by the oval hole?
    Tony
