1965 40083 fuel pump - NCRS Discussion Boards
  • Jack B.
    • July 31, 1983
    • 37
    I just removed a fuel pump from my 1965 fuel car. It is a mid November 1964 car. The flange has the 40083 stamped into it but I could not find any date code stamped into it. Should it have a date code and where might it be???
  • Russ S.
    • April 30, 1982
    • 2162
    Re: 1965 40083 fuel pump
    Jack, Have you searched the archives? There was a thread not long ago on fuel pump dating.
    • David L.
      • July 31, 1980
      • 3310
      Jack,
      I started a thread on 02/25/2011 entitled "AC fuel pump date code research date".
      Is you pump only stamped "40083" or are there 2 letters in the stamping as well?
      Dave
      • Jack B.
        • July 31, 1983
        • 37
        Dave
        Only 40083
        Nothing else
        It does have the AC on top
        Jack
        • David L.
          • July 31, 1980
          • 3310
          Jack,
          The stamped date codes started sometime in 1965 based on all my research on AC pumps. Over the years I have had a "40083" pump w/cast base and a "40083 IJ"(Sept. 1970) "over the counter" pump w/stamped steel base. Your "40083" should have a "PT 5623145" cast on the part that matches up to the engine block and I suspect it probably was made sometime in the Summer or Fall of 1964 since your car was made Nov. 1964. I believe that if disassembled the pump your would find some casting years, probably "64" with some radial line segments (which represent the month) around the year "64".
          I would suspect that the base on your pump is cast, not stamped steel.
          Dave
