'63 Fan Clutch - NCRS Discussion Boards
'63 Fan Clutch
  • Douglas G.
    • April 30, 2001
    • 58
    '63 Fan Clutch
    Is there a way to tell if it is necessary to rebuild or replace the fan clutch? The fan rotates and seems to slip but how does one know if it is slipping too much? Thanks for any help.
  • Mike M.
    • May 31, 1974
    • 8408
    Re: '63 Fan Clutch
    hold the clutch housing in your left hand then spin the shaft 6 to10 times. if the resistance to spining diminishes significantly, then its junk. and most 48 year old clutch fans with 50K+ miles on them are in fact worn out. mike
